Sandblast cabinet lighting - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2012, 11:34 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
My light fixtures are toast in the used sandblasting cabinet I got.
What kind of lights are guys using in their cabinets?
Anything special?
Outdoor flood lamps?
Old 12-03-2012, 01:49 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Well, I went ahead and made up a new light box. I'll be using ten 50PAR20's, mini flood halogens. Pics show 50 watt regular type bulbs which will be swapped out today for the proper bulbs.
I'm punching out rubber gaskets to put over the bulbs just below the threads to try to keep the sand out of the sockets. A s/s sleeve will press the rubber up tight to the socket hopefully locking everything out.
Name:	IMG_0421 (Medium).jpg
ID:	69557   Click image for larger version
Name:	IMG_0422 (Medium).jpg
ID:	69558   Click image for larger version
Name:	IMG_0423 (Medium).jpg
ID:	69559   Click image for larger version
The Following User Says Thank You to 123pugsy For This Useful Post:
knotheads (02-28-2014)
Old 12-12-2012, 02:12 AM
Silverback's Avatar
Boost Retard
I'd be a bit worried about that generating too much heat in a closed space using halogen bulbs.
Mine died too and I always felt that the stock florescent fixture sucked anyway, so I ended up throwing what I had sitting around at it. I had an old bathroom over the sink light, one of those flat on the wall with multiple bulbs things that I just replaced sitting around, took all the trim off of it, cut off a 4 socket piece with the bandsaw. The sockets were held to the steel backing plate with steel tabs that were easily bent to fold the sockets so the bulbs would fit flat against the backing plate, which got screwed to the top of the original light housing and wired into the original switch.
If I remember correctly, I have either 60W equivalent (12W) bulbs in there or a mixture of those and 100W equivalent CFL's in the sockets and it's _really_ bright. I like this setup
Old 12-12-2012, 03:32 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
I used it on Saturday and it's pretty warm alright.
Not gonna catch fire warm, but help keep the sand dry, warm.
It's really bright though. Can't have too much light.
sandblast cabinet FINALLY DONE critter119 Garage - Tools 13 12-29-2009 11:12 PM
Building your own sandblast cabinet Kevin45 Garage - Tools 17 05-07-2008 02:56 AM
Sandblast Cabinet Media stinger12 Garage - Tools 5 02-09-2008 05:22 PM
Sandblast Cabinet Hopper stinger12 Garage - Tools 2 06-11-2007 06:10 AM
Sandblast Cabinet Coating stinger12 Garage - Tools 8 05-17-2007 04:27 PM
