Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sandblast question
Old 03-11-2013, 07:13 PM
496CHEVY3100's Avatar
496CHEVY3100 496CHEVY3100 is offline
Built Not Bought
Last journal entry: 53 ad3100
Originally Posted by benchracer1 View Post
what grit would you guys recomend for sanding with a da? I definitely dont like the mess involved with sand either. I definitely like the idea of sand where you can and blast where you must. Taping seams is a good reccomend. I dont mind combining blasting, sanding and chemical stripping. 1 size doesnt fit all. frames and such I will definitely blast
Dont know if its rite or wrong but it what i was taught , if you use stripper we use aircraft stripper ,cover the panels you have stripper applied to and not working with plastic helps to keep from drying to soon ,dont get to far ahead cover one panel while working the next .as for sandpaper i use 180 to remone paint if you use finer grit 320/400 to strip paint it will cause heat that you dont need.
