Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sandblast question
Old 03-12-2013, 09:25 AM
Chevymon Chevymon is offline
Very good point, details details.
You can cover it with plastic after you apply it but if you do one other thing you don't much need to. That would be you don't "Brush" it like you do paint, back and forth. You pour some out then "spread" it out ONE WAY, with the brush. Don't back stroke, spread it out one way. The reason being the gases escape when you back stroke it and open the surface again. This makes a HUGE difference in how the stripper works. And this isn't out of my head, it says so in the instructions.
Another thing is you run some very coarse paper like 36 or 40 over it well to scratch the surface so the stripper can jump right in and do it's job.
Very good point to bring up there Dave!
Brian, there is a very good explanation of how the stripper works and some tips on using it in this link
Acetone • How to Paint Your Own Car, Auto Body Discussion Forum & Videos • AutoBody101.com
http://www.wmbarr.com/ProductFiles/A...%2025%2009.pdf
