Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sandblast warping heat MYTH.
  #36 (permalink)
Old 02-01-2006, 10:20 AM
oldred oldred is offline
Fat, You say if you remove ten feet of that hill you will have INCREASED surface area? You may have increased the LEVEL area but there would be a decrease in SURFACE area. But this is beside the point, removing metal is not the problem, peening and stretching(or compression maybe?) is. I think you need to take a closer look at what you are saying.
