Sandblaster Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2011, 07:08 AM
I recently bought a small handheld portable blaster with the small tank on top and I know you get what you pay for but I cant get any sand/media to flow out from the nozzle. I have the compressor regulating 80-100 psi from the tank and the gun says max 125. But I cant get any media to flow out. Also I was using I believe 20/40 grit which I now know is way too large, any suggestions of grit and sand type, maybe it was clogging but it didnt appear clogged.
Thanks and Any Help Would Be Great
Nick
Old 09-04-2011, 07:46 AM
delawarebill's Avatar
hand blaster
well a few things to ck.. remove the sand box cap, plug in air supply and hit the trigger.. if u are getting air flow out the sand box the internals don't work right.. it need a suction to work. next leaving the cap off, put your gloved hand over the tip and pull the trigger on/off... u should get air flow out the sand box then the sand is too large to flow..buy smaller sand...
Old 09-04-2011, 07:17 PM
One thing to watch for is overfilling the sand. It tends to "cake-up" and "bridge" the feed port if overfilled. I would start with a minimal amount of sand or media and go from there. I hope this helps...Ron
Old 09-05-2011, 03:25 PM
Thanks for the help, I used some smaller grit stuff and higher air pressure and it works great takes the old paint right off and does well on heavy rusted spots too.
Thanks Again
Nick
Old 09-05-2011, 08:09 PM
Any moisture in the air will transfer to the sand and clog up instantly.. Make sure you have a good dryer in the line.
Cabin Sandblaster fix!! azlo Garage - Tools 10 02-07-2011 07:26 AM
Sandblaster recommendations rusty105 Garage - Tools 21 11-12-2007 03:25 AM
yet another sandblaster question wildthing Garage - Tools 6 10-05-2007 09:01 PM
Just bought a HF sandblaster..... PairOf69's Garage - Tools 11 09-25-2007 09:24 AM
choosing a sandblaster jesse01 Garage - Tools 7 02-13-2006 06:54 PM
