Sandblaster recommendations - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-28-2007, 04:28 PM
scrot's Avatar
I just found this 20 gallon blaster on ebay.
Only $120
It is a pressure blaster, and uses a deadman valve instead of the ballc-o-c-k valve.
Harbor Freight has the same thing for $200, which is actually more than this one.
Ofcourse you'll have to pay for shipping, but if you live near the store, you can pick it up and save on shipping. I'm thinking real hard about getting this one.
  #17 (permalink)
Old 10-14-2007, 06:24 PM
Sorry to rehash an older thread... but does anyone have experience with the 125 lb Maxus?
Got a pretty good deal on eBay but I still would like some feedback or a review. Thanks.
  #18 (permalink)
Old 11-09-2007, 05:59 AM
Anyone with advice or a review on the Maxus 125?
  #19 (permalink)
Old 11-09-2007, 03:57 PM
scrot's Avatar
I don't have any experience with it, but it's obviously the same as the red one above.
  #20 (permalink)
Old 11-11-2007, 08:19 PM
I've got both a pressure pot blaster and a bead blasting cabinet from these folks. Both are very rugged units and are manufactured in the U.S.A. I've restored several cars utilizing them and have not had any problems. My experience with the imported units is that you are better off throwing your money out the window.
http://www.barrelblaster.com
  #21 (permalink)
Old 11-11-2007, 09:29 PM
Wiki Edits: 27
blaster wet blast !!
I have a 5 hp compressor and it won.t keep up with my bucket sears blaster. I have a booth big enough for a rear end with vacuum attachment. A contractor friend had a trailer mounted air compressor and said i could borrow it . diesel costs $ 3.50 per gal and he goes thru a lot. I bought a wet blaster from Northern tool. I have a 3500 pressure washer and it will take rust off 3 times faster than the air powered one...sand doesn't bounce back as bad with the air set up.. I used it outside and it goes thru a lot of sand. I am going to buy a pickup load until I can go to the dunes with a big trailer. It scatters sand everywhere but my closest neighbor is 1/4mile away. If you are in town sand would probably end up in your neighbor's yard too
  #22 (permalink)
Old 11-12-2007, 03:25 AM
Hi, thanks a lot for the feedback. I've been reading more on it. It seems that to avoid headaches; my best bet is to fix my eBay Arrow refrigerated air dryer and install before using sandblaster.
Originally Posted by timothale
... I have a 3500 pressure washer and it will take rust off 3 times faster than the air powered one...sand doesn't bounce back as bad with the air set up... It scatters sand everywhere but my closest neighbor is 1/4mile away. If you are in town sand would probably end up in your neighbor's yard too
Thanks for the heads-up. I'll have to build an enclosure (plywood, MDF or galvanized sheet) lined with 6ml plastic sheet as a temp booth first.
  #23 (permalink)
Old 04-30-2014, 06:19 PM
harbor freight verses eastwood
Ive always bragged on eastwood. Had a HB pressureized sand blaster. TOSSED IT. Bought Eastwood on line. Guess WHAT. Exactly the Same == just different color and over double the price. STILL JUNK!!! Hope you shop more wisely than I did. EASTWOOD, Im disappointed
  #24 (permalink)
Old 04-30-2014, 06:27 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Williew,
For your first post you replied to a 6-1/2 years old thread... that's gotta be a record ...
In any event, Welcome to Hotrodders
Header Fab Recommendations KernCountyKid Engine 7 12-27-2006 11:03 AM
Quality/ Effectivness of Eastwood sandblaster? JerryMopar Garage - Tools 2 12-01-2006 06:27 AM
Nitrous plugs recommendations please! hotrodf1 Engine 2 09-15-2006 08:10 PM
Master cylinder recommendations wheel-7 Suspension - Brakes - Steering 3 11-04-2004 02:43 PM
Has anyone used this or have any better recommendations (breathing apparatus?) senor_limpio Body - Exterior 3 09-23-2004 12:23 PM
