Sandblasting?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2007, 12:04 PM
Sandblasting??
I have a portable sandblaster and am very confused of what media to use in it. I want to be safe and will be blasting outside. I have heard that sand is bad but is it just when it is in the air, what about sweeping up afterwards?
Does anyone have any affordable suggestions? I have a blasting hood and am unsure of what other protective equipment I need. I am sandblasting a car hauler that has multiple rust spots and bad paint.
Thanks
Old 12-17-2007, 01:33 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Sand is silica...using that creates a dust and can give someone exposed silicosis which is bad news..It is not just the guy doing the blasting but also anyone in the neighborhood that may be exposed..I would suggest that you use a grinder with a flap wheel to get all the easy areas and then blast the corners and other places that are hard to get to..Use something like starblast that does not contain silica if you can get it..That is a brand name and you may need to do some calling to find someone in your area that has it..Also wear a dust mask under your hood..
Good Luck
Sam
Old 12-17-2007, 05:29 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Not only silicosis, but silica sand and paint are notr real compatible. You need something like walnut shels, aluminum oxide, or I believe it is called Black Beauty for blasting. Here's a site that explains what the different medias are. http://www.clemtex.com/abrasive/
Old 12-17-2007, 10:29 PM
Rag top bird's Avatar
Hot rods are still the king
There are a lot of ways to go here and Kevin has brought up Black Beauty and it is a good product but Duponts starblast works faster and is as clean(just blast and epoxy prime)
Cutting glass by sandblasting, Urban Myth? MARTINSR Body - Exterior 61 01-03-2015 08:48 PM
sandblasting a frame 5dogsisenuff Body - Exterior 23 04-16-2006 08:40 PM
sandblasting truck adam120674 Body - Exterior 8 03-29-2006 08:27 AM
sandblasting 70sportside Introduce Yourself 3 08-24-2004 03:20 PM
Sandblasting question ChrisMiddleron Body - Exterior 6 12-27-2003 12:50 PM
