| Register now (free) or login to remove ads | |
Tweet
#16
I didn't use any. I had a bunch of thick glass that was all cut to the same size. I just built a frame around the glass and set it into the the drum. I put the arm holes where they were comfortable. The wooden frame was just landscape timbers and scrap wood. The shelves came from the junk pile in the back of Lowes. (that's where I got my powdercoat oven too) Sadly it all gone now. My house burned down over the summer. |
| Sponsored Links |
#17
I will add this. Don't bother with a siphon system unless you really love to waist time. Go to Harbor Freight or someplace like that and get a cheap pressure pot. (the biggest one you can) It's also not too hard to make one.
#18
i made one out of a barrel a while back, it worked well. however for the price of buying the gloves, glass, etc i would just buy one premade from harbour freight or somewhere like that. which is what i eventually did, i sold the barrel and bought a store bought when they went on sale
#20
TP has some very nice plans, that allow you to build a very nice and professional looking and perfroming sand blasting cabinet. The largest deluxe kit they sell will allow you to build a very, very large caninet , one with a 45" door, complete with everything needed for only $299.00. I have access to a old 275 Gal oil tank, that I am debating turning into a large sand blasting cbinet with there kit.
http://www.tptools.com/p/335,18_Bui...ted-System.html |
#21
Sandblast Cabinet
Thanks alot. Still time to make a decision. Icepick |
#22
helpplease
Hey do you still have he plans on how to buld it |
#23
szingsheim
Hi I like the drum idea do you still have the plans cheers Gordon. |
#24
Sorry for the long wait!
The barrel is a standard 55 gallon drum. I used a D.A grinder on the left side of the barrel (one without the bungs on it) 1.5 inches from the edge of the barrel to make the door hole. On the bottom of the door hole i left it flat so i could use hinges to open it. Common door rain seal was used on the inside of the hole to keep in the media. the door itself is made from 3/4 mdf with 4 holes for fresh air to enter the blast chamber. the vents you see in the picture are sofit covers from the home depot it helps keep in the media but lets the air in. I used a D.A to cut the window hole and used 3/4 plywood for the frame of the window. To match the curve of the barrel for the frame hold the frame to the outside of the barrel and trace the curve, use bandsaw and attach with drywall screws. I used permatex on all mating surfaces. The window pannel frame is 1" L channel mitered at the corners and welded together for ease of plexi changes (when window stars to get bad). It's held in with 1/4" bolt that is welded to the drum and hold the window pane frame with decorative knobs from the DEPOT. The window is standard plexi that i cut using a knife by scoring and snaping. The mating surface of the window to the blast cabinet has window foam seal to make it air tight when the knobs are secured. The arm holes are made with a D.A grinder and the collars are made of 1/16" steel made into a band then welded, then the total part is welded to the hole in the drum then permatexed. The light is from harbor freight 9$ and the gloves as well 7$. The rack inside is from a fridge i found in the desert and welded together. The small screen is from a old microwave i found next to the fridge. (holds small parts better). On the right side of the drum are the two bungs. The large one ia a standard 1-1/2 pipe thread which i used a sink install kit to connect to my shop-vac to pull the fresh air through. The small hole had a seal on it, i removed it and ran my pressurised blaster through. On the bottom of the inside of the drum i drilled a hole that i used a sink stop, to hold the used media and to empty when it gets full. As far a specs go i'll have to do some measuring and post again online. But with the picture supplied and being this IS a website for gearheads one can only make my idea better!
L8R ZING |
#26
buggmann
hey i would like to build my own also
any plans i could get you can send them to me i like all the ones on here thanks buggmann |
#28
Plans
Hello,
I no this is an old post I was considering buying a cheap harbor freight cabinet and saw your buildup and have all the materials I need already. Just wondering if you can share whatever plans you have to assist me in my build. I also wanted to add that alot of time you can get info by doing a patent search at freepatentsonline. Thanks again, |
#29
here's mine
Mine cost me about $2.50 to build (cost of my hinges)...this is about as cheap as it gets. Just scrap plywood, I use heavy rubber gloves, 2 trashbags to extend my arms into the cabinet. I just snipped a small area out of the bottom of the bag for my hand to slip through. For the window I used the piece of plastic in those el cheapo frames (its what I had on hand). The plastic is frosted over and needs to be replaced. I hinged the frame, caulked the edges, drilled a hole in one corner of the cabinet so I can just push the material to that hole. The material drains nicely back into my blaster. I have a mesh filter in my blaster to catch any pieces of debris. So there ya go- it is functional, not pretty, but a coat of paint and then it looks good and functional.
#30
Hi there buddy, i LOVE your cabinet and just went and bought 2 drums to start my own! only thing i dont really understand well is how you made the arm holes and got the gloves attached and sealed there.. lol, maybe i just dont recognize some of the terms you used coz im in SA and the stuff is called something else... i dono, but can you maybe please explain a bit in detail how you made the holes and attached the gloves? i dont want to screw up my drums though i did buy two just for incase but they damm expensive here by us. and also can you give me a few pointers on stuff to keep in mind when building the cabinet? thanks so much in advance. |
| Similar Threads for: "Sandblasting cabinet homemade" | ||||
| Best Sandblasting Media | Granddad's51 | Garage - Tools | 28 | 04-12-2009 09:52 AM |
| Building your own sandblast cabinet | Kevin45 | Garage - Tools | 17 | 05-07-2008 03:56 AM |
| Cutting glass by sandblasting, Urban Myth? | MARTINSR | Body - Exterior | 46 | 05-22-2006 07:05 AM |
| blasting cabinet help | HzSandman | Garage - Tools | 3 | 06-14-2004 11:56 AM |
| Sandblasting question | ChrisMiddleron | Body - Exterior | 6 | 12-27-2003 01:50 PM |
