Hotrodders Bulletin Board
#1
Sandblasting cabinet homemade
Has anyone ever made a homemade blasting cabinet and if they had do they reccomend it and do they have plans for it?
#2
Those are not all that hard to make..Lots are built in a "home made fashion" to accomodate the needs of a particular shop..just a basic box large enough to fit the parts..the gloves are available as replacement items from several supppliers and a good glass window..
Look at one sometime and you can derive all the info you need.. Just a big box with a window and the glove pieces placed in convenient positions for the user..plywood works fine tho I like to use either MDO or HDO coated plywood for those.. OMT
I would rather make it work than make it popular..And if it does not work it will not be popular.. |
#3
I am also making one, i made mine with the upside down pyramid at the bottom for the sand trap, its all out of MDF board
i just need a good gun, who makes good quality ones? Brendan |
#4
Be sure to check out the Hotrodders Knowledge Base. There are a couple of articles on this in the Garage - Tools category. Here's a link:
Garage - Tools Articles.
-- Body and exterior tips || Freeing a stuck engine || Soda blasting || Narrowing a rearend || John Deere Blitz Black paint || How to find cheap parts || Hotrodding glossary || Transmission identification || Rust || Cheapo paint job || How to identify a Ford V8 || How to title a hot rod...and hundreds more articles. |
#5
I am looking at building a cabinet what kind of glass would be best i got my sanblaster at harbor freight
#6
i have plans for a simple cabinet that uses one sheet of plywood and a 5 gallon bucket fill up the bucket, insert the siphon tube, blast, and then when done just shovel everything back into the bucket i can also change the plans up so that it has a hopper on the bottom, but it would require a second sheet of plywood, and the plans were originaly drawn up for someone who had a single extra shet of plywood to use for the project lemm dig out the plans and get back to ya .. |
#7
TP Tools and Equipment makes and sells kits to build your own cabinet plus carry guns, foot pedels, plastic sheets and gloves.
For the glass find a good glass shop in your area and get a piece of tempered glass (you will want to buy the plastic sheeting to go over the glass to keep from frosting it up). I bought a piece of 18"x24"x1/4" for 25 bucks here. Wayne S |
#9
szingsheim - Glad to see you added those pics to this thread. It will help a lot of guys wanting to build there own cabinet!
#10
Go to this link for a few more pictures of szingheim's home built unit. http://www.hotrodders.com/forum/new...new-118463.html And note the great solution for when the sand/media bridges in the bucket - an inexpensive sander strapped to the side.
#11
Here's mine. It's not as nice as Szingsheim's. I love the design because I can rotate it to adjust for my height. (sitting or standing) The siphon system is very slow. I plan to build a pressure pot as soon as I get a welder. I'll probably weld in some new arm holes as well. The flanges I used are a tad small for my arms.
#13
Blast Cabinet Plans
I am a woodworker and welder. I am interested in your rough plans for the blast cabinet. icepick |
#15
Blast Cabinets
Hi,i got the plans and materials from tpi,i have used mine for about 10 years,works really well,only complaint is,that i should have made it larger than plans called for.
Back to top |
Similar Threads for: "Sandblasting cabinet homemade"
| Best Sandblasting Media | Granddad's51 | Garage - Tools | 28 | 04-12-2009 08:52 AM |
| Building your own sandblast cabinet | Kevin45 | Garage - Tools | 17 | 05-07-2008 02:56 AM |
| Cutting glass by sandblasting, Urban Myth? | MARTINSR | Body - Exterior | 46 | 05-22-2006 06:05 AM |
| blasting cabinet help | HzSandman | Garage - Tools | 3 | 06-14-2004 10:56 AM |
| Sandblasting question | ChrisMiddleron | Body - Exterior | 6 | 12-27-2003 12:50 PM |
