sandblasting and painting a frome - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2011, 09:43 PM
i have a 1949 chevy pickup and i need help redoing the frame and also restoring it if someone can help me. i would like to get the frame first if possibe.
thanks in advance
tyrone
Old 07-28-2011, 09:47 PM
hp246's Avatar
The fastest, cheapest, safest way to start is to find a professional blaster to blast the frame. To have a pro do it will cost you a couple hundred bucks. You will spend more than that on materials and equipment to do the job.
From there, you will have to evaluate the frame for damage and repair that damage.
As far as painting, you don't mention if you are restoring or just building a hot rod. Your paint choice will depend on that decision. If building a hot rod, there are a number of options out there. Do a bit of research and pcik the option that fits your needs.
Old 07-29-2011, 12:43 PM
When sandblasting the frame the best thing is an epoxy primer then urethane SS right over that in a "wet on wet" fashion. No saiding needed.
Old 07-29-2011, 02:03 PM
ogre's Avatar
the 'Duracell Project'
you obviously don't said.
i always said it.
Old 07-29-2011, 02:44 PM
No honestly, you don't have to said it, if you are you are wasting your time. SAND, SAND! Geeeez.
Sandblasting eganddg Body - Exterior 5 03-08-2009 06:17 PM
sandblasting EVENT LADY Body - Exterior 1 04-05-2008 11:03 PM
Sandblasting?? kvsbmsdws Body - Exterior 3 12-17-2007 11:29 PM
sandblasting 70sportside Introduce Yourself 3 08-24-2004 04:20 PM
sandblasting etc. spikes_50 Body - Exterior 15 05-08-2003 10:28 AM
