Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sandblasting question
Old 12-26-2003, 07:19 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Glass bead is not good for paint removal. It bounces off the soft paint, then etches the surrounding area, this makes the next paint even harder to get off the gun, you need the polished finish on the gun, use wash lacquer thinner, you will get better results. As for removing powder coat you will need a sharp abrasive and be careful on the base metal as you will abrade it. Powdercoat is usually pretty tuff.
