sandblasting respirator - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2006, 06:01 PM
What kind of filters does everyone use with his 3m half-mask? Do I need to change them every 30hours or so, like when spraying isocyanates?
I own a fresh-air supply but because of the fact that I blast a long distance away from the booth, it's not practical to uninstall the turbine with all the tubing everytime I need to blast something small
Old 10-27-2006, 06:24 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Probably. Not like the ISO's but here is what I do.
I use the general type for blasting & base type paint. It has the prefilter over the "canister" filter and I keep the pre filter changed after each session. This should keep the majority of the nasty's out and make the canister last longer.
I use the AO Safety respirator from HF which has the canister then a fiber type prefilter. I double up on the pre filter and change those and do the canister as needed,which is a personal matter of choice IMO.
MAIN thing is FIT to your face. ANY facial hair is a BIG issue so either shave or get a full face type if you like beards.
Cutting glass by sandblasting, Urban Myth? MARTINSR Body - Exterior 61 01-03-2015 09:48 PM
Homemade fresh air respirator? dh79 Body - Exterior 25 12-15-2009 06:31 PM
$100 fresh air respirator 36scsc Garage - Tools 13 06-18-2005 02:20 AM
Scuba respirator for isocyanates? McDeuce Body - Exterior 5 02-01-2004 03:51 AM
Sandblasting question ChrisMiddleron Body - Exterior 6 12-27-2003 01:50 PM
