Sanded through to the base! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2005, 06:35 PM
While wet sanding the clear coat I started to notice that I had gone too deep and hit the basecoat. Using Detron 2000 DBC and Transtar Kwik Gloss clear. What would be the proper procedure to repair this. It is hardly noticeable but I know it's there.
Old 04-22-2005, 07:06 PM
On what panel did you cut through? and where on the panel? What color? The best way to repair this is to mask off the surrounding panels then scuff the damaged panel with a grey scotchbrite, then spot in some color with light coats blending the color out from the damaged area gradually. Then clear the complete panel. If there is a good bodyline to do a tape rollback on you could keep the clear confined to a smaller area. Doing a clear coat blend is also an option but not for the inexperienced-takes really good gun/paint control and experience. Bob
Old 04-22-2005, 07:34 PM
The car is a 2000 Mustang Laser Red. I cut through on the left quarter panel just rear of the wheel opening and above the plastic bumper cover. I can see very tiny flecks of gray (DP50LF) but when you step away from it you cant see it at all.
Old 04-22-2005, 07:45 PM
You're lucky with that body design being that the quarter is fairly small and is seperated from the roof. You should be able to keep the repair within the quarter panel. Hopefully you have left over basecoat so matching will not be a problem.
Old 04-22-2005, 08:13 PM
Thanks for the help, I'll let you know how it turns out.
Old 10-12-2006, 06:53 PM
Last journal entry: Boat
Isn't laser red a "factory candy"? You might be out of luck...
Old 10-12-2006, 06:57 PM
colormecrazy's Avatar
Paintshop Dog
Out of Luck! But, he should be able to spot in the color even if it is a tri-coat. But, the unlucky part is blending a tri-coat is a little tricky.
E9 is a color that is available in DBC in a 2-stage, so Montey may be OK!
Good Luck Montey!
Old 10-12-2006, 07:02 PM
adtkart@aol.com
Since the original post was 1 1/2 years ago, I would hope he has it fixed by now. LOL
Aaron
Old 10-12-2006, 07:05 PM
Paintshop Dog
OOOOPPPSSS!
Thanks Aaron!
Old 10-12-2006, 07:08 PM
This was a year and a half ago and it has been fixed. The job was an overall and the original paint "laser red" was a tri coat. Finishmaster mixed the job as a 2 step base and clear and added 20% more pearl to the base. As far as the sanding through problem, I repainted the entire panel and everything was fine.
Old 10-12-2006, 07:10 PM
Goofballs.
Fresh Base reacting with old base on spot repair myfamiliacc Body - Exterior 11 03-20-2005 08:07 PM
Knowledge base lluciano77 Hotrodders Site Suggestions and Help 1 12-10-2004 07:21 PM
Ignition timing advance question. Terje Engine 14 07-31-2004 04:03 PM
base circle cam ? syclone Engine 1 07-25-2004 07:08 PM
Help please-sanded through base coat fastblueheeler Body - Exterior 11 10-01-2003 07:32 PM
