Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sanded through my clear coat please help
Old 01-02-2011, 01:33 PM
Centerline Centerline is offline
Wiki Edits: 49
For a novice painter I would suggest you sand the entire stripe, shoot a fresh coat of base and then re-clear. Blending can be a bit tricky, especially your first time. As its just a stripe its not that much work to do the entire section over.
