Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sanded through my clear coat please help
Old 01-02-2011, 07:26 PM
cjperotti cjperotti is offline
When I posted the edges lifting I was referring to the areas where you broke through the clear. Those are critical areas when doing a repair.
If I were doing this job I would scuff the whole hood with 2000 wet sand, remask the stripe and reshoot it, then reclear the whole hood. That way you avoid a tape edge at the stripe.
