Sanderson or Hedman Hedders? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2003, 07:14 PM
New Member
I am in the process of putting in a 305 into my S10. I have the engine assembled and changed my mind on using stock manifold.
Now I am trying to decide on headers that wont set me back too much more money than I already have into this....
Sanderson Headers
3/8" thick gasketless flange, 1-1/2" primary tubes, 2-1/2" collectors
$199.00
3/8" thick gasketless flange, 1-5/8" primary tubes, 2-1/2" collectors
$229.00
Hedman Hedders
1/4" thick flange, 1 1/2 in. primary tubes, 2 1/2 in. collectors
$119.95
I guess the real difference here is the flange. Will 1/8" be that much of a difference? What is your experience with either of these companies?
Old 11-04-2003, 07:25 PM
all i know is go with the bigger one.....more air flow
Old 11-04-2003, 07:34 PM
302 Z28's Avatar
I have a set of Sandersons for my street rod that I have not installed yet. I am not very impressed with the ceramic coating on them, it appears uneven and splotchy. the Sandersons are going to run you more than the Hedman I think. I would go with the Hedman 's.
The 1-1/2" tubes will give you more low end. The 1.5/8" tubes will perform better at higher RPM with all conditions being equal. Have you looked at Hooker also?
Vince
Old 11-04-2003, 07:40 PM
poncho62's Avatar
Wiki Edits: 5
Bigger tubes on your headers can hurt performance, especially on lower cube motors. Smaller tubes will help your bottom end torque. If you go too large, you will lose bottom end. Something to think about. Bigger is not always better.
Old 11-04-2003, 07:49 PM
New Member
I hear that a 1/4" flange leaks all the time. Is this true? Any tricks on how to get around these leaks?
Old 11-04-2003, 07:50 PM
poncho62's Avatar
Wiki Edits: 5
Good gaskets.....................
Old 11-04-2003, 08:23 PM
mitmaks's Avatar
Last journal entry: Grille
does TTI make them for sbc's?
Old 11-04-2003, 09:22 PM
lluciano77's Avatar
Don't even bother buying headers if you get 1 1/2" primaries. You are better off with stock exhausts with that diameter. Headers have to be retorked all the time, rust, and are louder. If you still think you need headers then get some 1 5/8" Hedmans.
Also, if you get headers I would recommend buying some Percy's header gaskets. I have been using them since they came out and have never had a leak. I have even reused them multiple times. Once they set initially, I have noticed that they don't need to be retorqued as often.
Old 11-04-2003, 11:11 PM
fox's Avatar
fox fox is offline
Canadian
i also looking around for headers. wouldnt the 1 1/2 tube be better for the 305 since it lacks torque?
Old 11-04-2003, 11:28 PM
New Member
go with the headman headers, thats what i have on mine, i just used some good copper gaskets thats all
Old 11-05-2003, 12:07 AM
lluciano77's Avatar
305s have decent torque. 1 5/8" primary tubes won't lose any of that torque down low. 1 1/2" tubes are a waste of money on anything above 300 cubes.
Old 11-05-2003, 12:15 AM
fox's Avatar
fox fox is offline
Canadian
alright.
i see that the hedman dont make 1 5/8" for my car (82 Grandprix). The same price pretty well as the hedman, Hooker COMPETITION HEADERS, they are 1 5/8" TUBE OD, 3" COLLECTOR OD part #2451. do they sound like a good way to go? thanks alot
Old 11-05-2003, 12:25 AM
lluciano77's Avatar
Get the Hookers. That would be your smartest choice. It would be worth it to get the coated ones.
Old 11-05-2003, 01:27 AM
