? on sanding - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-21-2010, 06:35 PM
roger1's Avatar
You bet. Sounds like you got a handle on everything now.
Good luck
  #17 (permalink)
Old 06-24-2010, 09:49 PM
roger1's Avatar
Originally Posted by pappastang
i do have all the paint off,and its been at least 3 to 4 weeks and no flash rust i will scuff it up and vac the car, after the w@g remover, ill use a tac rag.
I was curious and did a search on tack rags and came up with this:
tack clothes from Home Depot
Looks like tack rags are OK if you get good ones. I still don't see much reason to use them on bare metal before epoxy.
  #18 (permalink)
Old 06-24-2010, 10:17 PM
no need to to use a tac clothe/rag only purpose is for base and clear. just clean the surface of the metal and get it primed then you can work on getting the thing straight. if your doing it at home then yea panel by panel would be a good idea so you don't get ahead of yourself
  #19 (permalink)
Old 06-25-2010, 05:18 PM
i was just going to use it to wipe down the car just before i sprayed the epoxy, some one told me i should, thats why i asked . again thanks for the input, im going monday to pick up the epoxy and 2k primer, im sure ill have more ?s
Block sanding help with pics holy85 Body - Exterior 9 08-07-2009 10:10 AM
sanding scratches showing esahlin Body - Exterior 10 07-29-2009 12:42 PM
Interesting test on sanding base coat paint (against the data sheets recommendation) MARTINSR Body - Exterior 208 03-22-2007 10:52 PM
Sanding is the art pepi Body - Exterior 3 08-02-2006 10:40 PM
Color sanding and Buffing questions. Z-Money Pit Body - Exterior 1 05-30-2005 09:41 PM
