? on sanding - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2010, 08:00 AM
? on sanding
i sanded my 7 mustang down to bare metal with 80 grit, do i resand it down with a different grit before i spray epoxy on it then the primer, thanks for any input
Old 06-20-2010, 09:05 AM
roger1's Avatar
80 grit will be fine.
You can wash it down with water and dawn dish soap. Dry it , then wipe it down with a waterborne w&g remover, let dry and your ready to spray. Be sure to use an automotive grade w&g remover or you can have problems.
Old 06-20-2010, 10:10 AM
HOLD ON HERE, we are talking bare metal ! DO NOT wash with water, DO NOT wash with waterborne wax and grease!
If it is bare metal use a solvent borne wax and grease and honestly, if you just removed everything with 80 grit, what is there to contaminate?
We are a little late with this, but next time, DO NOT STRIP THE ENTIRE CAR! Strip a panel or two and then get it into primer.
I would still recommend this now, if you can't sand the whole car with 120 or 180 right now to remove any flash rust, I would be sanding a few panels SPOTLESSLY CLEAN then get them into primer. Then move on to the next panels.
But to strip the whole car with 80 and a day or more later prime it? You are going to be priming over flash rust!
I seriously doubt you have all the paint off, I doubt you have done the "detail" work around body lines and edges and the like.
Go over every panel with 120 or 180 to finish the job and clean up any flash rust and paint or primer left from the 80 grit and get it into epoxy primer. If you do this over the entire car, you will have flash rust again! So do a panel or two and get it into primer. Then move onto the next few panels after your epoxy has kicked.
Old 06-20-2010, 10:14 AM
roger1's Avatar
Really Brian?
I have never had any problem with flash rust if water or waterborne is wiped off immediately.
Oil from the D/A would be the biggest thing. There could be other contaminates as well from the sanding debris.
Primering over minor flash rust is done all the time. I've never seen it cause problems. Remember back in the days when we were supposed to use metal conditioner? It was impossible to use that stuff and not have flash rust before primering.
Also, here's a quote from Barry's "The Perfect Paint Job":
"All bare metals and aluminum should have 80 grit DA scratches.
Bare metal is always best cleaned with #700-1 Waterborne Wax and Grease Remover then let it set 30-60 minutes before applying the epoxy
Old 06-20-2010, 11:05 AM
Originally Posted by roger1
Really Brian?
What exactly "Minor flash rust" means is up to interpretation! What one may see as "minor" another would see was RUSTED and must be removed.
As far as the 80 grit scratches, I have to disagree. We are talking BARE METAL here, it isn't going to have TRUE 80 grit scratches anyway, unless a grinder is used the 80 grit scratchs left from your typical paper aren't going to be "80 grit" scratches like those 80 grit scratches left in filler or something.
And epoxy adheres so well, 180 or 120 is PLENTY in my opinion.
But here lies the problem. The 80 grit isn't going to get every bit of the primer and rust off unless you work very hard, possibly not at all no matter how hard you work in some areas. It is scratching "around" stuff. While the finer paper is going to REMOVED all the little specs of everything.
If you want to have an 80 grit scratch, then sand it all real well with the 180 and then go back over with 80. But I feel that is an overkill personally.
Personally, seeing a newbe strip a car with a sander or grinder spells disaster in my experiance. I am trying to come down to a more "controled" condition for the poster. Striping each panel carefully with 120-180 and getting them in epoxy while the metal is clean is more "Likely" going to produce a good job than saying "priming over flash rust is ok" and he primes the whole car that has been sitting in bare metal for three weeks. Or a car that has taken him three or four weeks to strip (like my bathroom remodel) and has a nice coat of rust.
On the waterborne wax and grease on bare metal, yeah, I guess I am old school and hearing "water" on bare metal gives me the creeps. But I guess it is ok if Barry says so.
Old 06-20-2010, 11:21 AM
TucsonJay's Avatar
What you see after metal prep is not rust, (iron oxide)... it is "iron phosphate", which will cause no problem.
I would not tempt fate with water on bare metal. If you get away with it, great! ...but if you don't....
Old 06-20-2010, 11:30 AM
roger1's Avatar
I understand what you are saying. A person just has to use logic here depending on shop conditions as far as humidity and like you say, time, and assess whether flash rust is a problem or not. I don't have a problem with it here in San Angelo, TX. There are certainly some advantages to primering the whole car at once too. Especially since you can follow up with a high-build primer (filler too if necessary) without sanding before the re-coat window has passed. If you do one panel at a time, you are probably going to pass the re-coat time and have to sand and re-coat the entire car in epoxy before moving on. That's a whole extra step and extra cost in primer.
I agree. Epoxy adheres well to metal sanded in finer grits. Heck, it even adheres pretty well to unsanded metal.
However, since I use SPI products, I will use Barry's recommended procedures for my stuff. I'll make sure the metal is clean with whatever it takes but go back over it with 80 grit. That last part doesn't take that much extra time to do.
Old 06-20-2010, 11:37 AM
roger1's Avatar
I hope you don't use metal prep with epoxy. That's not a good combo.
Old 06-20-2010, 11:42 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
most flash rust is from iron deposits in the water. i wash every car with dawn soap and water. it is the only way to get one clean after blasting. epoxy over mild flash is no problem. scuff it with red scotchbrite and apply 2 coats and your good to go.
Old 06-20-2010, 11:55 AM
OH GOD YES I am with you there! But if you are doing it at home, it sometimes is a whole different ball game. This is why I recommend it to home newbes. It is up for them to make a call, but if they are aware, it can save them.
Go with the manufacturers recommendations is what I aways say!
Old 06-20-2010, 12:06 PM
BarryK's Avatar
Thank you!!!!!!!!
There are 100's of ways to make an epoxy, there are a 100 ways to make a wax and grease remover.
My tech sheet applies to my stuff only and PPG, Duponts tech sheets applies to theirs only.
Do not use one tech sheet for another product, period.
Old 06-20-2010, 12:15 PM
You just can't go wrong listening to the people who sell and back the product!
First off, even if it goes against what you think, like my thinking the 80 grit is an overkill. 80 grit as Barry says is CERTAINLY not going to hurt anything. It WILL provide a great surface for the primer. Following his recommendations for the product he sells is always going to be a good way.
Old 06-20-2010, 04:17 PM
i do have all the paint off,and its been at least 3 to 4 weeks and no flash rust i will scuff it up and vac the car, after the w@g remover, ill use a tac rag . is there a solvent that i should wipe the car down before i put the epoxy on. if i run into any problems, i will do a panel at a time. thank you all for your answers
Old 06-20-2010, 04:51 PM
roger1's Avatar
Gosh, will all that's been said here, I'm surprised to see you ask this. Go by the P sheet for the particular epoxy you are using. I doubt it will say to use anything besides w&g remover.
Many paint jobs have been ruined by wiping down with lacquer thinner used as a w&g remover before epoxy. Epoxys in general won't cure properly in the presence of acids.
Also, save the tack rags for later. No need for it here. I don't know for sure but I think it can cause problems too.
Old 06-21-2010, 05:53 PM
i thank you again
Block sanding help with pics holy85 Body - Exterior 9 08-07-2009 10:10 AM
sanding scratches showing esahlin Body - Exterior 10 07-29-2009 12:42 PM
Interesting test on sanding base coat paint (against the data sheets recommendation) MARTINSR Body - Exterior 208 03-22-2007 10:52 PM
Sanding is the art pepi Body - Exterior 3 08-02-2006 10:40 PM
Color sanding and Buffing questions. Z-Money Pit Body - Exterior 1 05-30-2005 09:41 PM
