sanding!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2005, 04:41 PM
ss396si's Avatar
sanding!!
hi everyone,
im in the process of sanding my 69 chevelle gas tank,rear and other parts. my question is: is GM paint made with lead in 69? What kind of mask can i use to protect myself? im using a wire wheel brush and a mask( N95) to clean the metal. what can i use to protect myself?
thanks
Old 04-25-2005, 10:14 PM
Definately there was lead in the paints in 69, wear a good particle mask and you'll be fine. Keep your sandwiches away from the work area.
Old 04-25-2005, 10:16 PM
ss396si's Avatar
i dont bring food when i work on my car. but i do it outside i wore a faceshield and 2 N95 mask. so i dont breath it in
Old 04-25-2005, 10:28 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
I use the regular dual cartridge resp. from harbor for all my sanding and priming,ect. I buy extra pre filters and change them out when dirty. I use the good charcoal type for my bc/cc.
I hope that tank has had plenty of time to get the fume's out.
Old 04-25-2005, 10:31 PM
ss396si's Avatar
i seen one in home depot today a 3M dual cartidrge resp for 28.99. its for toxic dust and other things. im goin to buy that instead of using the other ones. who knows it might not work as well as i think it is.
Old 04-25-2005, 11:03 PM
Bee4Me's Avatar
The one I'm refering to is like the charcole one but has smaller canisters.
It's usually around $20.00
DA sanding vs hand sanding Kevin45 Body - Exterior 31 07-19-2005 02:37 PM
Color Sanding jcclark Body - Exterior 9 03-15-2005 09:21 PM
Sanding single stage? Project87c10 Body - Exterior 6 11-05-2004 01:44 PM
wet sanding and saving my finger tips.... onebadmerc Body - Exterior 14 12-30-2003 06:41 PM
Sanding, Dry vs Wet, Air vs Elec Bluepen Body - Exterior 3 05-12-2003 04:45 PM
