sanding base for clear coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2009, 06:21 PM
Hi all,
I'm looking to get clear coat the bonnet I was working on tomorrow. What is the best sand paper grit to use on the base before applying clear coat?
I'm looking for a flat, deep shine.
Old 08-14-2009, 06:30 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
All we look to do is just check over the base for nibs and trash..If you must sand use a 600/800 grit for that..should not have to sand if you are in the recoat window..
Sam
Eliminate filler pinholes with dental pik and credit card cboy Body - Exterior 8 05-21-2009 05:48 AM
Seal Coat Color Vs Base Coat Color Question Houston54 Body - Exterior 15 10-09-2007 06:38 AM
How to spot repair base coat? formula_pilot Body - Exterior 3 04-15-2007 08:53 AM
base coat paint and base concentrate questions student blake Body - Exterior 13 08-02-2006 10:33 PM
sandpaper... 38 special Body - Exterior 14 10-11-2005 04:30 PM
