Sanding base coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2007, 03:48 PM
Sanding base coat
Here's my problem. Sprayed some base on the trunk lid and I can still see some scratch marks left from sanding the 2K primer. If I sand it smooth with 1500 wet and sand thru to the 2K in spots, can I blow on a couple more coats of base without problems or will it wrinkle. I haven't cleared it yet. Whats the best way to fix this?
Old 03-14-2007, 04:02 PM
Countilaw's Avatar
Cox Custom Cars
You're on the right track. Sand with some 400-600 wet. Mix a little Dawn dish washing liquid in with the water. After you have it smooth, you may need to spray a couple of coats of primer and resand just like before. Just make sure you have all the previous sanding scratches out. Wash the area good with some more Dawn, rinse, dry. Wipe down with some Isopropyl (rubbing alcohol) and then tack.
Then spray your new base coat on.
Even if you had sprayed on the clear coat, it would be the same process.
Good luck and get back with us with your results.
Old 03-14-2007, 04:44 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Whar the count said..sand it and reshoot the primer to fix those scratches then carry on with the base coat..
Sam
Interesting test on sanding base coat paint (against the data sheets recommendation) MARTINSR Body - Exterior 208 03-22-2007 10:52 PM
Repairing Base Coat 1958FordF100 Body - Exterior 9 03-06-2006 10:07 PM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
base coat clear coat wally Body - Exterior 8 12-12-2005 06:44 PM
About to spray base coat, newbie question... flipp121 Body - Exterior 20 10-16-2005 08:52 PM
