Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sanding before cutting and buffing
  #21 (permalink)
Old 07-09-2012, 12:04 AM
67Elcamino's Avatar
67Elcamino 67Elcamino is offline
After a couple panels with a soft block I switched to a hard block and im
Noticing its knocking down the peel and the wave much better. Im being very very careful with corners and non-flat surfaces. 1000 grit with hard block is working wonders. Thank you all
