Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sanding before Slick Sand
Old 04-27-2011, 10:14 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Hopefully you have set that body out in the sun for a week or two to allow it to cure well before painting it..Just a tip is to block it out with 80-100 grit and get it straight before going to 180 and the slick sand..Actually if you do a good job of filling and blocking you may not need the extra material as a good primer will do fine..
Sam
