Sanding before Slick Sand - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2011, 09:08 AM
boris_thespider's Avatar
Evercoat says to sand with 180 to 220 grit before applying Slick Sand. I've heard that some people just use 80 grit because they're going to use 2 gallons of Slick Sand. Is using multiple coats of SS over 80 grit saving me any sanding time? By the way, this is a fiberglass body.
Old 04-27-2011, 09:23 AM
cyclopsblown34's Avatar
Colorsanding painter
I use slick sand type products on 180 grit scratches. Filler and glaze for anything coarser.
Old 04-27-2011, 10:12 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
cook the body for at least 3 days in the sun , hit with 100 grit then 2 coats of epoxy . personally epoxy is all i use.
Old 04-27-2011, 10:14 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Hopefully you have set that body out in the sun for a week or two to allow it to cure well before painting it..Just a tip is to block it out with 80-100 grit and get it straight before going to 180 and the slick sand..Actually if you do a good job of filling and blocking you may not need the extra material as a good primer will do fine..
Sam
Old 04-27-2011, 10:48 AM
Can I go from 80 grit right to 180? Or do I have to hit it with 120 in between?
Old 04-27-2011, 11:11 AM
I usually hit 120 in between.
Old 04-28-2011, 08:10 AM
put up or shut up
You can go straight to 180. Some guys use that stuff over 120, which is the same as a worn out piece of 80 grit.
advice for Slick Sand? xpsyclonex2002 Body - Exterior 11 09-04-2009 09:45 PM
Slick Sand SHIFTY101EASY Body - Exterior 7 02-07-2007 08:00 PM
Slick Sand problem oldred Body - Exterior 2 09-20-2006 11:07 AM
Slick Sand help! evilone Body - Exterior 14 11-12-2005 02:48 PM
slick sand 5dogsisenuff Body - Exterior 11 08-09-2005 08:11 PM
