Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sanding blocks
Thread: sanding blocks
Old 10-26-2012, 05:11 AM
jcclark's Avatar
jcclark jcclark is offline
The Penny Pincher
Last journal entry: Hanging Bumpers
I use the Durablocks along with some others that are more rigid.
I even use a wood 2X4 piece.
the nice thing about the Durablocks and the wood ones is they are
so easy to true up.
Take some stick-on 80 grit paper and stick it
to a flat surface (like my countertop) and run the block
over it till it's even.
None of my blocks are that true when new.
the Durablocks sand easily and really show the low spots
after sanding.
If I want a really rigid Durablock, I can attach a piece of
plexiglass to it. Round the edges a little with sandpaper
to remove the sharp corners.
The Following User Says Thank You to jcclark For This Useful Post:
cyclopsblown34 (10-26-2012)
