Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sanding compound curves...
Old 12-28-2009, 09:56 PM
wyomingclimber wyomingclimber is offline
Originally Posted by cutterbond
I have to wonder if your primer is fully cured being that it is so cold, it might make it too soft for blocking hence the gouging.
I also had problems with Omni primer not setting up, but if it's not clogging your paper then it's your technique.
I actually have had a problem with my paper clogging as though the primer wasn't fully set up in places. Impossible, though. I painted the thing in the middle of the summer and it sat around for months in 80 degree weather.
Overall, I wouldn't use the Nason 2k again. It was really hinky to use and now I'm just praying there's nothing wrong with it that could cause me problems down the road.
