Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sanding compound curves...
  #31 (permalink)
Old 12-31-2009, 12:13 AM
oldBodyman oldBodyman is offline
"OBM,will sticky back paper stick to that spray foam without tearing the foam up when you replace the paper?"
All sticky back papers are not the same, 6" DA usually works fine, long board usually has a death-grip. You can test your's on the back side first, if it's too sticky run it over your pant leg once or twice to kill the stick. Don't leave the paper on over night, it won't come off without heat.
Have fun with it, it can be a real time saver.
