sanding on contour lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2003, 01:52 PM
Rubberman2003's Avatar
on mh 84 z28 i have a nickel size rust spot on the drivers door, its on the contour line though. Can i use my 80 grit to rip the rust off and then 400 tofaether it out without messing the line up?
Old 06-28-2003, 05:21 PM
adtkart@aol.com
If you have a rust spot it is likely going to take more than just riping it out and feathering the paint to do the repair. It will take some kind of filling to bring it up to the level of the other metal/paint. Depending on how deep the rust is, you may end up grinding through the panel. The body lines are no thicker than the rest of the panel.
Old 06-28-2003, 09:58 PM
this rust is very minor just like other rust spots i had to sand, i dont think it will need filled, im just worried about grinding the line all to crap.
Old 06-29-2003, 07:59 AM
302 Z28's Avatar
You first must make sure you remove and kill all the rust so that it will not come back. Just sanding it away is not enough, it must be chemicaly killed with something like Ospho(sp).
Vince
Old 06-29-2003, 08:15 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
This is where a spot blaster really works good. be carefull if you use a grinder.Good Luck
Old 06-30-2003, 02:38 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Use a block to bring it back in shape. Using just your hand will leave a depression.
Kevin
