Sanding orange peelin clear before final clear coats - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2012, 10:20 PM
67Elcamino's Avatar
I know this topic has been beat to death but Im wondering if I can get away with shooting my last two clear coats without completely eliminating all orange peel..
Ive done so with a test panel and it seemed to be work out well. Im thinking since I plan on cutting and buffing my last coat anyways it shouldnt be a problem but Im wondering if shooting clear over these tiny unsanded areas in the clearcoat would cause any adhesion problems in the future?
Im just afraid to cut through the clear since I didnt quite get the first coat of clear over the basecoat as thick as I wanted. This is why Im hesitant to sand anymore
Name:	sanding clear.JPG
Old 05-25-2012, 04:14 AM
deadbodyman's Avatar
Wiki Edits: 11
I'd use a gray scuff pad and hit the little bits of trash with 600 by hand just enough to knock the sharp peaks down some,dewax , then two coats of clear
Old 05-25-2012, 07:26 AM
67Elcamino's Avatar
I have scuffed down with 600 but havent completely flattened the orange peel as you can see in the picture. Im sure my 2 coats of clear will fill them but was wondering if it would cause any adhesion problems with my last two coats?
Old 05-25-2012, 11:22 AM
67Elcamino's Avatar
Bump...
I want to shoot the two coats of clearcoat on this panel tonight and was hoping to get some advise before doing so..
You all spoiled me with all the quick and excellent advise on this forum..
Old 05-25-2012, 12:47 PM
cyclopsblown34's Avatar
Colorsanding painter
If you don't have any sand throughs where the clear is gone and you see basecoat, I'd go for it.
Best Color Sanding Abrasives (final clear coat fine grits) 777funk Body - Exterior 1 07-25-2011 06:57 PM
sanding clear then repaint with base clear agian questions tiptopss Body - Exterior 8 04-20-2010 07:09 AM
final sanding with 2 coats of clear? Saddlebacks Body - Exterior 3 10-08-2006 08:15 PM
Mix Clear with Final Base coat prior to clear x711 Body - Exterior 10 04-08-2006 07:55 AM
Do more coats of clear..... Rick WI Body - Exterior 2 04-08-2005 08:30 PM
