Sanding Primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2009, 10:21 AM
Sanding Primer
Sorry for the double post, but heres a really stupid question. Is this normal for the primer to look like this after sanding? Its dried for 24 hours, and is being sanded with 180 grit. I wasn't sure if the sanding scratches should be a lighter color or not.
Old 04-23-2009, 11:51 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
I can't tell by the picture but 180 is pretty aggressive,
that's great for initial sanding, to get something straight,
but it does need to be sanded more fine before painting over.
Usually 400 to 600.
Most will sand with 180 and reprime, then again sand, finer, for
show car work and straight finishes.
For me, doing collision repair, 400 to 600 is all I ever need before
paint, so I usually don't go that far down in grit.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
Wet sanding filler primer kaw550 Body - Exterior 9 04-27-2011 09:17 PM
Question reguarding painting over old OEM paint + primer sanding Finaltheorem47 Body - Exterior 2 10-09-2008 10:16 PM
Sanding the *%^$&# primer all off the fiberglass parts Ripped Body - Exterior 7 09-01-2007 08:56 PM
Is wet sanding epoxy primer okay? Ripped Body - Exterior 9 04-25-2007 02:32 PM
