Sanding primer
I shot a 2 part epoxy primer on the firewall of my Model A coupe and after it dried I found imperfections under the primer.
My question is can I just scuff the surface and apply filler(bondo) over the bad area or do I have to take all the epoxy off and starft from square 1. Thanks - Jerry
X2,same here
if it's adhesion issues then take it down to metal. It all depends on the damage. In a perfect world I'd do some rough metal work BEFORE epoxy then finalize it. In a normal world I block it, determine what needs to be pulled up with stud pins or dolly's and what can be simply filled. I like to sand my epoxy with 80-180 grit after blocking cause I'm not secure with filler edges that don't properly feather out, which is a true sign of bad adhesion. My opinion hinges on whether or not the epoxy was applied thick enough to do that. If you get it epoxied at a blasting company that sucks it will be thin, sucky adhesion, and I'd rather just take it off. If it's epoxied in house and there's a tad to block out AND get in some good scratches then that's what I do.
| Wet or Dry sanding primer | outlaw17 | Body - Exterior | 12 | 05-14-2011 04:33 PM |
| Primer repair/sanding through | lugog | Body - Exterior | 3 | 07-14-2009 02:32 PM |
| Sanding Primer | JamieK | Body - Exterior | 1 | 04-23-2009 10:51 AM |
| can i spray epoxy primer over etching primer without sanding? | wickiewicked240z | Body - Exterior | 1 | 08-29-2006 09:07 PM |
| After sanding primer can I rinse off with water? | SplitFire | Body - Exterior | 6 | 01-21-2006 09:51 PM |
