Sanding and Priming - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2002, 10:05 PM
Post Sanding and Priming
How should I san the front clip and prime it with a coat of paint. Just so that It looks ok till I get a real good paint job. Its got a little rust and a little bondo work. Whats the best sand paper and easiest way to do this job?? Thanks
Zee
Old 07-12-2002, 11:59 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Main goal for this type of job is to get the surface very clean and a good bond for the paint. Don't want to cause problems later for the paint shop when you get the good job done. Wet sand the entire surface with 320 wet or dry until it is totally sanded. Then go over the surface with wax/grease remover (lacquer thinner works too but will dissolve paint if you linger so rub it down quickly). Clean out rust to bright metal, dont leave ANY rust or it will bubble the paint eventually, guaranteed. Prime all bare areas with etching primer before putting on a coat of "suede". A quart of etching primer will go a very long way. Only need a light coat as a base for filler primer. DON'T strip off good solid original paint thinking bare metal is the best starting point. Bare metal is much harder to paint than a good, solid, well sanded original paint.
As far as the bondo is concerned, if it is well bonded to the surface and not too thick (nothing over 1/16" thick) then just sand it and finish it like it was regular paint. You can primo out the body work first or leave it rustic, doesn't matter.
Old 07-16-2002, 07:13 PM
Post
Unless you're using a 2 part primer, don't just prime over bare metal and drive the car around. Ordinary laquer base primer is porous and the metal will rust right through it. An epoxy primer should seal it well enough, but a thin "Guide Coat" of any color paint will hold it better as well as being a sanding guide for later.
Priming and Blocking Chevy535 Body - Exterior 22 09-23-2006 02:14 PM
Stripping Whole Car 47Dodgecoupe Body - Exterior 14 08-25-2006 07:56 AM
Removing Rust & Priming my Runningboards horvath Body - Exterior 2 12-03-2004 08:06 PM
Sanding w/ wire brush? spookabilly Body - Exterior 14 07-03-2003 03:39 PM
Sanding, Dry vs Wet, Air vs Elec Bluepen Body - Exterior 3 05-12-2003 03:45 PM
