Sanding/Recoating IMRON Clear 500S - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2004, 12:40 PM
Red face Sanding/Recoating IMRON Clear 500S
I have been reading this forum since I started painting my own cars. I ran into a problems when using Dupont IMRON (polyurethane) followed by the Dupont IMRON 500S Clear. It says you can apply it wet on wet. Unlike PPG and Akzo Nobel Technical instructions, the Dupont does not discuss very well the prep required if you do not spray wet on wet, ie., sand with 600 after 16 hours or whatever. Anyways, I sprayed the clear wet on wet with the solid color. I go some pieces of trash in it and need to sand/buff or recoat to clear it up. If it says to scuff it up, what grit of sandpaper would I use with that. (600-1500)? Was thinking anything above 600 and the clear would not stick. I used a DA sander with 600 grit and tried to buff it back out, but its dull. Should I just be able to recoat it now? Thanks for any help. Opie.
Old 08-04-2004, 12:43 PM
BarryK's Avatar
Re: Sanding/Re-coating IMRON Clear 500S
RE: 6 & 5 series clear:
This clear is not made to be wet sanded and buffed, yes you can buff but you may want to practice on your driveway first.
This clear is affected by humidity and air temp and size of air-cap as to when you can wet-sand and re-coat, thats why the tech sheets are vague, if they are.
Rule of thumb on this resin is wet-sand to re-coat in 24-72 hours, if it sands gummy, its not ready yet. High heat with high humidity can actually slow total cure down.
This resin has a high charge so it will stick very well to a 1000 wet-sand job or coarser with no problem
Remember this is made to be a 15 yard paint. From 15 yards back it should look good. Their words not mine.
(Not sure if it was 15 feet or 15 yards, now that I think about it, its been awhile)
