Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sanding single stage?
Old 11-05-2004, 08:03 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
If you use the hardener, by all means color (wet) sand it and polish it. It is only when hardener isn't used in enamels that sanding and polishing doesn't work.
