Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sanding single stage?
Old 11-05-2004, 08:49 AM
onebadmerc's Avatar
onebadmerc onebadmerc is offline
I need a bucket of arc sparks
Metallics will cause you a problem if you wet sand them and try to buff them out on a single stage paint job. If you didn't use enough hardner or put atleast 3 good solid coats on it, I wouldn't wet sand and buff it out either.
