Sanding SPI epoxy - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2012, 09:33 PM
mitmaks's Avatar
Last journal entry: Grille
Sanding SPI epoxy
It's been over 7 days since I've applied SPI epoxy. I want to put some filler over some low spots. Which grit should I sand epoxy with? I was thinking 120 would be fine or should I go with 80 grit?
Old 01-17-2012, 04:39 AM
shine's Avatar
Last journal entry: some progress
use 80 grit
Old 01-17-2012, 09:23 AM
Barry recommends appling filler during the recoat window.
Old 01-17-2012, 09:31 AM
shine's Avatar
dont worry about the recoat window. very seldom will you be ready for filler that soon after stripping. an 80 grit anchor pattern is the best thing to apply filler on.
Old 01-19-2012, 06:18 AM
deadbodyman's Avatar
Wiki Edits: 11
I've done it both ways ....but I still sand anyways for piece of mind
Old 01-19-2012, 06:55 AM
Shine, define anchor pattern for this novice, please.
Trees
Old 01-19-2012, 07:23 AM
shine's Avatar
scratches..................
or blasting profile.
Old 01-19-2012, 07:34 AM
Trees
http://www.nortonsandblasting.com/ns...ves-anchr.html
Prep, Epoxy, Filler, Sanding Procedure Order... wyomingclimber Body - Exterior 3 05-21-2008 10:21 AM
sanding SPI epoxy? 62galaxiguy Body - Exterior 2 08-17-2007 09:41 PM
Is wet sanding epoxy primer okay? Ripped Body - Exterior 9 04-25-2007 01:32 PM
sanding epoxy???? 62galaxiguy Body - Exterior 3 11-07-2006 03:22 PM
can i spray epoxy primer over etching primer without sanding? wickiewicked240z Body - Exterior 1 08-29-2006 09:07 PM
