sandpaper - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2006, 01:47 PM
sandpaper
my friend and i are looking to wet sand his 87 chevy and we are wondering what kind of sandpaper you use to wet sand it and also to say hi to the group
Old 03-21-2006, 05:53 PM
roger1's Avatar
What are your intentions to do with the finish after wet-sanding?
Old 03-22-2006, 05:23 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
If you're color sanding (before buffing) I think nothing beats the
Meguiars brand "Nikkons". It's the best stuff I've ever used but it is
expensive and only comes in finer grits, I think starting with 1000
and goes up. It really lasts and cuts easily.
Nortons "Black Ice" seems as good to me at half the price.
That's all I use now. After that I would go 3M.
Don't buy cheap paper, you'll use twice as much so you won't save anything
and you'll work yourself to death with it.
This is one area where it really pays to get good stuff.
Old 03-22-2006, 01:39 PM
well we plan on painting his truck black. so we are looking to find out what the best (grit i suppose it would be) of sandpaper and maybe get a couple of hints along the way thanks
Old 03-22-2006, 02:13 PM
302 Z28's Avatar
Apply enough coats of primer so you can block sand with 180. Use a guide coat to gage your progress on the initial block sanding. Once it is flat wet sand with 400 to 600. Wet sand your final coat with 1500 to 2000 then buff.
Vince
Old 03-22-2006, 03:32 PM
roger1's Avatar
Are you planning on repainting directly over the sanded finish?
Or, were you planning on primering first?
Sandpaper Grading Grit Charts 327amc Body - Exterior 2 01-17-2013 03:50 PM
sandpaper... 38 special Body - Exterior 14 10-11-2005 04:30 PM
What grit sandpaper is this? Z-Money Pit Body - Exterior 1 05-30-2005 10:23 PM
Using a drill for sanding, cutting, etc. alex_0227 Garage - Tools 12 03-23-2005 08:50 AM
what grit of sandpaper DOBIED Body - Exterior 1 02-14-2003 10:51 AM
