Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sandpaper need help.
Old 01-18-2013, 04:42 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
You shold be able to get 4-600 DA paper at any body supply store...For a trailer the red scuff pads work pretty well...
if you want to eliminate any scratches in the future you should use a coat or two of primer if you and with anything coarser than 400 wet or 320 DA,so lets say you blocked out the car with 180 ,you wont be able to get the scratches out by just sanding again with 400,you'll need to prime and sand again with 400 or 320 da ...When I wet block with 400 I always give it a breeze over with wet 600 ...dont for get your guide coat...
