SAS Half Mask - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2006, 07:25 AM
SAS Half Mask
I just bought a SAS half mask unit from a friend for $150. I think it was a pretty good deal. However, I am concerned about protecting my eyes from the ISO's. What do you guys recommend when using a half mask?
Thanks!
Old 10-24-2006, 04:38 PM
colormecrazy's Avatar
Paintshop Dog
There are goggles available at most paint stores for about $15. If you have an overlap problem, put the goggles under the mask. The air supply will have positive pressure, that should keep the paint out of it. Or, you may consider attaching the two more permanently, to avoid any leeks at the top of your nose.
Good Luck!
Your All Half Right and Half Wrong zvagabond Hotrodders' Lounge 10 02-09-2006 11:44 PM
question about respirators? firechicken383 Body - Exterior 35 10-23-2005 06:30 AM
Half inch offset on frame jaxhome Transmission - Rearend 9 10-20-2005 11:14 AM
half shaft ujoint 81 vette 1-bassman Transmission - Rearend 2 09-29-2004 02:27 PM
respirator air or full face mask w/ canisters??? luckydevil Body - Exterior 6 04-23-2004 05:26 PM
