Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SAS Half Mask
Thread: SAS Half Mask
Old 10-24-2006, 04:38 PM
colormecrazy's Avatar
colormecrazy colormecrazy is offline
Paintshop Dog
There are goggles available at most paint stores for about $15. If you have an overlap problem, put the goggles under the mask. The air supply will have positive pressure, that should keep the paint out of it. Or, you may consider attaching the two more permanently, to avoid any leeks at the top of your nose.
Good Luck!
