Sata 3000 air pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2008, 08:08 AM
I just bought a new 3000 hvlp digital. I am a little confused about how to adjust the air pressure. Am I correct by pulling the trigger and setting the digital read out to 25-29 psi? When I do that the pressure coming out of the tip seems high to me.
Thanks!
Old 12-07-2008, 08:59 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Here you go..
http://www.southernpolyurethanes.com...your%20gun.htm
run 100 lbs at the wall and then start with the pressure low and work up till you have good atomization and pattern. Might take some tries until you get it right for yourself..shoot a test panel and keep working on dialing your gun in till it shoots wet and slick..
Sam
"Basic of Basics" How do I paint my car myself? Centerline Body - Exterior 5 11-07-2011 07:14 AM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
Air pressure regulator Irelands child Body - Exterior 8 05-07-2008 03:19 PM
using a respirator robs ss Body - Exterior 10 08-23-2007 06:31 PM
has anyone tried the new sata 3000 rp 5dogsisenuff Body - Exterior 0 06-12-2006 05:39 PM
