-   -   sata jet (http://www.hotrodders.com/forum/sata-jet-108537.html)
FIREBIRDTONY 02-07-2007 09:37 AM
sata jet
:confused: hi. i just purchased a satajet 90 for $25 dollars from a pawn shop gun looks great but painter left paint in gun so the nozzle was clogged. i tore the gun down and like the old days soaked the gun in aircraft stripper and then cleaned with thinner. will this affect the gaskets in side or should i be prepared to buy a rebuild kit. also is 200 a good price for a sata nr2000 in like new but used condition not clogged with paint lol!!
baddbob 02-07-2007 12:33 PM
The satajet 90 is a good gun, you might have damaged some of the seals in the air control portion of the gun while soaking in aircraft stripper. Buy yourself a rebuild kit and put her together.
chadsbodyshop49119 02-07-2007 05:15 PM
Probably a fair price for a used 2000 get it down to 150 and buy buy buy
FIREBIRDTONY 02-07-2007 05:25 PM
I TRIED! BUT 190 WAS AS LOW AS HE WOULD GO. I SHOT THINNER THROUGH IT AND IT SHOT GREAT. NOW I JUST GOT TO LEARN TO SHOOT HVLP. IM USE TO THE BINKS AND DEVELBISS TYPE GUNS
chadsbodyshop49119 02-07-2007 05:31 PM
I would use it primarily for base.. seems to do best for that..
SHIFTY101EASY 02-07-2007 06:11 PM
when you say "im used to binks and devilbiss guns" do you imply they don't make hvlp guns? sorta confused?
DougMN 02-07-2007 06:49 PM
Not a bad price for the NR2000. look on ebay for a good idea what they are going for.
FIREBIRDTONY 02-07-2007 08:12 PM
no im sorry i ment old school siphon feed foogers nonhvlp or conventional
SHIFTY101EASY 02-07-2007 08:36 PM
oh okay, i was trying to figure out what that could mean....like HVLP is a brand term/name or something that has become generic since other people have copied it...like every body filler can sorta generically be called "bondo" now.
mitmaks 02-09-2007 07:09 PM
depending on tip setup it works great for bases/clears.
big-john45 10-15-2007 12:38 PM
SatajetB spray gun
Anyone have any info on this satajetB gun? John
