sata jet - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2007, 09:37 AM
FIREBIRDTONY's Avatar
Last journal entry: the rear body panel
sata jet
hi. i just purchased a satajet 90 for $25 dollars from a pawn shop gun looks great but painter left paint in gun so the nozzle was clogged. i tore the gun down and like the old days soaked the gun in aircraft stripper and then cleaned with thinner. will this affect the gaskets in side or should i be prepared to buy a rebuild kit. also is 200 a good price for a sata nr2000 in like new but used condition not clogged with paint lol!!
Old 02-07-2007, 12:33 PM
The satajet 90 is a good gun, you might have damaged some of the seals in the air control portion of the gun while soaking in aircraft stripper. Buy yourself a rebuild kit and put her together.
Old 02-07-2007, 05:15 PM
Custom builder and painter
Last journal entry: Another test fit of the axle
Probably a fair price for a used 2000 get it down to 150 and buy buy buy
Old 02-07-2007, 05:25 PM
I TRIED! BUT 190 WAS AS LOW AS HE WOULD GO. I SHOT THINNER THROUGH IT AND IT SHOT GREAT. NOW I JUST GOT TO LEARN TO SHOOT HVLP. IM USE TO THE BINKS AND DEVELBISS TYPE GUNS
Old 02-07-2007, 05:31 PM
I would use it primarily for base.. seems to do best for that..
Old 02-07-2007, 06:11 PM
SHIFTY101EASY's Avatar
Last journal entry: Stripping Paint + Buying New Metal
when you say "im used to binks and devilbiss guns" do you imply they don't make hvlp guns? sorta confused?
Old 02-07-2007, 06:49 PM
Not a bad price for the NR2000. look on ebay for a good idea what they are going for.
Old 02-07-2007, 08:12 PM
no im sorry i ment old school siphon feed foogers nonhvlp or conventional
Old 02-07-2007, 08:36 PM
oh okay, i was trying to figure out what that could mean....like HVLP is a brand term/name or something that has become generic since other people have copied it...like every body filler can sorta generically be called "bondo" now.
Old 02-09-2007, 07:09 PM
mitmaks's Avatar
Last journal entry: Grille
depending on tip setup it works great for bases/clears.
Old 10-15-2007, 12:38 PM
SatajetB spray gun
Anyone have any info on this satajetB gun? John
Sata Jet 90-2, Anyone Use This Gun Yet? 67goat Body - Exterior 11 10-13-2010 09:08 AM
the painters deal of a life time! sata jet digital 2 yellowlexus Body - Exterior 1 02-10-2007 08:16 AM
Ingersol Rand Paint Gun Like Sata 2000?? camaro freak Body - Exterior 1 05-13-2006 01:22 PM
Sata Jet 30000?? New Gun On Market 67goat Body - Exterior 0 05-04-2006 04:00 AM
Sata Jet Rp, Advice Please On Usage?? 67goat Body - Exterior 2 05-03-2006 08:56 PM
