Sata RP digital - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2009, 01:26 PM
Wraith's Avatar
Born to lose,living to win
Sata RP digital
Hi everyone just picked up a sata jet rp digital 1.4,im new to the digital guns and havnt figured out how to set the air pressure on the gun.So how do you set the pressure? im use to regulator lol so this is new to me.
Old 04-09-2009, 08:51 PM
satas are set up for high volume hose and high pressure, you should use a direct fitting to the gun, and then the knob directly above your hand on the back twist that for your air pressure, i just got a sata jet 3000 ditgial and it was all new to me as well, just remember that they use higher pressures compared to other guns
Old 04-09-2009, 09:01 PM
Wraith's Avatar
There just a fitting on the gun, no knob so i can put one on the gun to adjust the pressure?
Old 04-09-2009, 09:09 PM
have a picture of the gun or can you find one online??
Old 04-09-2009, 09:20 PM
Wraith's Avatar
Here is a picture
Old 04-09-2009, 09:26 PM
the red circle is your air adjustment, just stick a fitting on the bottom (blue) not a pressure regulator just a air fitting, then use the red knob to adjust your air pressure since as you adjust you will be able to see the pressure your set at on the ditgial display, and it shows up on the red aarow,
then on the side you have your spray adjustment, so you can use a nice fan or a rifle lol, then your fluid adjustment is way at the top
Old 04-09-2009, 09:34 PM
Wraith's Avatar
Thanks man this is my frist good gun i bought, so was a little lost with the digital air adjustment lol
Old 04-09-2009, 09:40 PM
holly crap, thats alot of money for a first gun, i would only spray color/clear with this gun, get a less expensive gun for primer, personally im a huge fan of iwata spray guns, im curently looking at buying one, the sata was given to me to pratice for a compatition that im in coming up for painting, and yes it was a little working trying to figure everything out hope you like it
Old 04-11-2009, 10:32 AM
Wraith's Avatar
I have a cheaper gun for primer lol this sata is my colour gun.
Old 04-11-2009, 05:43 PM
have you figured it out and sprayed it yet?
Old 04-12-2009, 12:16 AM
Wraith's Avatar
Benen messing with it, cant figure out how to lock the pressure?
Old 04-12-2009, 01:18 AM
like stated before, satas are set up for high volume hoses, and high volume fittings, so if your having pressure problems i bet thats why
Old 04-12-2009, 01:23 PM
Wraith's Avatar
going to have to get a new fitting the one that i have on it now you can hear air leaking from it.
Sata RP bubbling material in cup cyclopsblown34 Body - Exterior 4 03-30-2009 07:58 AM
Sata Digital RP DEEZY Body - Exterior 3 04-19-2006 03:28 PM
