Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sata spray gun help
Old 01-02-2011, 09:36 PM
Kris D Kris D is offline
Not sure if this is the answer but most paint guns you can pull the trigger about halfway and just air will come out. Usually used to set air pressure. Might be what your feeling? I know on my SATA 3000 HVLP when you pull the trigger halfway it pushes your hand back a little.
