-   -   sata spray gun help (http://www.hotrodders.com/forum/sata-spray-gun-help-190039.html)
angel85lx 01-02-2011 04:44 PM
sata spray gun help
every once in a while my nr 2000 will make a loud noise and it feels like a shake when i pull the trigger. Now its always on the first pull and when the gun sitting for a few minutes wihile i wait for the flash coat.
Kris D 01-02-2011 09:36 PM
Not sure if this is the answer but most paint guns you can pull the trigger about halfway and just air will come out. Usually used to set air pressure. Might be what your feeling? I know on my SATA 3000 HVLP when you pull the trigger halfway it pushes your hand back a little.
angel85lx 01-03-2011 01:38 AM
no this was like a shake on the air cap. And it only happened one the first pull after it will not do it.
cyclopsblown34 01-03-2011 12:16 PM
Have you left the aircap soak in reducer or thinner for a few hours or more? Does it have lots of removal and reinstallation over time? I'm thinking the seal on the air cap might've gotten a little out of shape and the air pressure popped the seal back in place. It has a plastic seal that is like a u cup if I remember right, they go bad and are subject to deformation if soaked in solvents and then installed.
angel85lx 01-03-2011 06:00 PM
well I am going to replace the air distribution seal. I will check that seal when I get back home.
