SATAjet 2000, yay or nay?
There is a sata jet 2000 on CL by me for $300. Is this gun any good? What is it worth? It looks like new and comes with a 1.3 tip. Due to limited funds, right now I am looking for a gun I can use for primer and base coat. I know I will need another tip for primer. I have never painted a car so this would be my first gun.
http://rockford.craigslist.org/tls/1759206569.html Thanks |
yeah, no. A friend of mine picked up a 3000rp for $350 off of ebay 3 years ago still wrapped in plastic. AND dont use the same gun for primer and base coat. You can pick up a CHEAP primer gun from Harbor Freight.
Buyer beware, there are a number of painters on here that have been burnt with ebay paint gun buys.
Used only a few times, and the gun has wrong needle installed and looks like it was dragged behind a truck. If it was a 200 RP I would look for $250, being an NR not worth $75 to me, its a good base gun but you better have a compressor with some balls to run that gun and a cheater $700 5-hp is not going to do it except for spot work or maybe a whole side at once. The NR is an scfm hog. |
Just like previously stated, the NR 2000 isn't worth a crap as far as I'm concerned...I would stay away from it. I bought one a couple years ago and I don't like it at all.
The atomization seems to be inconsistent (job to job, even cup to cup with same paint), which led to making adjustments to the gun mid-stream, typically yielding unfavorable results. I've had better results from a Snap-on HVLP.... |
| 385 stroker combo yay or nay | whatsamotor | Engine | 7 | 05-10-2009 08:11 PM |
| 307 yay or nay | DeathRattle | Engine | 14 | 03-25-2008 09:24 PM |
| 1975 Gremlin...Yay or nay? | BMM | Hotrodders' Lounge | 21 | 04-17-2007 07:31 AM |
| help! satajet nr 2000 | FIREBIRDTONY | Body - Exterior | 2 | 02-12-2007 06:43 AM |
| 64 toploader yay or nay? | Chumpy | Transmission - Rearend | 2 | 12-18-2002 11:32 AM |
