Satin/brushed aluminum wheels - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2012, 07:33 PM
I've got a gloss black 37 ford with a small amount of stainless and aluminum trim. I used a gray scuff pad to knock the shine off all the trim and get a slight brushed finish.
My wheels are polished aluminum, but I don't try too hard to keep a high shine on them because I want that consistent satin/brushed look. I've just used a standard polish to touch them up a bit. After 3 years, the wheels are pretty spotty, and I've got to do something better to get get the look I want.
I've scuffed aluminum before, and I know it's not easy to get a professional look, especially on an irregular surface. I am looking for some suggestions on how to attack this.
Oven cleaner or some other chemical?
Alumabrite?
Media blasting?
I was considering using polish or something to clean them up good and then using a dry wool pad on my polisher/sander. I was thinking that might dull it just enough but only leave minimal scratches.
Old 10-28-2012, 08:21 PM
BOBCRMAN@aol.com's Avatar
I have some old 15x12 aluminum wheels on my gasser project. These were stored outside for thirty years and not really fine shape. I scuffed them up with 120 paper on a lathe then went to 320 then course scotchbrite/WD40. Look like new and match the look of the car. There is one not too great pic of wheel in my file/journal.
Old 10-28-2012, 09:55 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Scotchbrite type pads are made for Roloc adapters..I used those to clean some alloy wheels and got a good finish..Just some alloy cleaner and they stay looking good..Meguirs makes a ball type polisher pad that works well also in a drill motor for the fine finish.
Sam
Brushed Aluminum lower dash insert.. Bonneville462 Interior 9 03-20-2013 12:35 PM
Brushed Aluminum Look on Steel TheMonkey Body - Exterior 3 04-18-2006 03:30 PM
Aluminum wheels Guy Hiltz Hotrodding Basics 4 09-30-2005 10:12 PM
Brushed aluminum adtkart Interior 5 11-10-2003 06:26 AM
Old aluminum A/R wheels... Steve Lawn Body - Exterior 4 05-02-2003 09:18 AM
