Satin clear over acrylic enamel! Martin SR. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2011, 05:03 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Martin SR.
I have a young fella that wants to paint his engine cases, brake drums, front end parts on a motorcycle. His concern is gas softening and/or washing off the clear. What would you recommend for paint and a satin clear for this job?
Thanks.
Old 04-12-2011, 06:25 AM
Satin clear
Hello,
Any good quality 2part clear when properly cured shouldn't soften with gas, I've even washed cleared parts with lacquer thinners before (very carefully), just be careful till your sure its cured and it should be fine,
clear over acrylic enamel mitmaks Body - Exterior 8 04-20-2010 08:55 PM
I need some options acrylic enamel , sand clear, or just leave alone crystalbluevib Body - Exterior 11 04-03-2010 09:39 AM
Acrylic enamel base with a Urethane Clear. JeronimoMB Body - Exterior 8 05-28-2009 08:45 PM
Clear urethane over acrylic enamel? Kawdennis Body - Exterior 3 05-07-2007 02:46 PM
clear over acrylic enamel David Pringle Body - Exterior 4 06-04-2005 07:39 PM
