old trick, I forgot about. Thanks for the reminder to save my old covers.
I agree, if you know what you are doing there is no need to get oil all over your new engine, breath in all the smoke from the headers, cut up valve covers or any of that.
Set them with the motor off. |
wrong. IF you know what you are doing....you will be able to set them and be done with it.
You can set them with it running and when you are all done and there is oil everywhere and you have brain damage from all the smoke you inhaled. The preload will still be wrong. Lots of people think you can set a motor "by ear" but in the end all you end up with is a wiped out cam. Same thing as people who think they can set the timing "by ear" all you end up with is a motor that runs lean and hot and burns up plugs. You need to use numbers and proven techniques that set all the lifters the same and to the manufacture specs. |
setting a hyd. cam by ear has been proven time and time again to be the best method- as far as your set + 1/2 turn method I just helped a guy who did that and couldn't get his engine to run for more than a few seconds... once he had oil pressure the extra 1/2 turn kept the valves from closing. Know what he said? "I did it just like the book told me to!" Albeit he was an elecrical engineer and I get nervous when they pick up anything more than a souldering iron.
[QUOTE=Double_v23]wrong. IF you know what you are doing....you will be able to set them and be done with it.
You can set them with it running and when you are all done and there is oil everywhere and you have brain damage from all the smoke you inhaled. Correct! do it all the time, as to bran damage and oil smoke from doing the adjustment .................. a bit of a stretch, would'nt you agree. But the first line I am on board totally. |
Yeah, I have read old car manuals that say to tighten the rocker arm adjusting nut to 20 ft/lbs....that doesn't mean you should.
I don't believe there is a cam manufacturer out there who recommends messing with the preload with the motor running. |
Just exaggerating a bit....but if it takes you a really long time...you never know! |
| Help Me Identify These Valve Covers | bjr | Engine | 11 | 08-25-2005 08:16 PM |
| Valve covers | Hellzapoppin | Engine | 2 | 06-23-2003 09:37 AM |
| Best gaskets set for SBC valve covers & engine | Jag Daddy | Engine | 3 | 05-21-2003 05:47 PM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
| Stock eliminator | 78 monte | Engine | 5 | 01-02-2003 05:10 AM |
